The changelog sheet top bar is transparent
Upload description: corylowry12
Got an update, change log sheet top bar is transparent
Emby
That color is from the theme colors.
Did you use transparent colors in some of you theme colors ?
Those colors does not match the colors on the first screenshot.
Did you change the settings after?
Trying to open the changelog again from settings and show how it looks.
And it is a different color, I think it is because it was pulling the color from the song I had playing.
Hum possible then can you upload that song to https://upload.symfonium.app so I can try to repro it should not generate colors with alpha.
I have uploaded it, and the description is my username.
The image does not have a cover, do you have a cover.jpg or something else for that album that you can join ?
I uploaded it, and the description is my username ![]()
Can’t reproduce. I’ll add a random workaround to ensure no alpha in that bottom sheets headers but this is still strange.
