Changed Files are not recognized for Offline-Caching?
I use Symfonium via Soundsonic and Navidrome.
I had an audio-file (mp3) which I’ve edited and re-upload to navidrome.
In detail I cut something away, so the filesize and duration of the song changed…but symfonium doesn’t recognize it.
What is the right way to make symfonium be able to recognize such changes, without removing (single or all) files from cache, and resync it?
Navidrome
  1. Cache one Song on symfonium
  2. Change the file in Nvidrome
  3. Re-Start sync in Symfonium (nothing changed)
rethus
There’s nothing in the API to know that the file is changed or not so not much solution than recaching the files manually.
ok, but how.
You mean to delete a single file and do the sync again?
Yes you remove it from cache then cache it again.
