Casting to TVs and Sonos
I am experiencing a consistent issue where high-resolution FLAC audio files with a sample rate or bit depth higher than 24-bit/48kHz (e.g., 24-bit/96kHz, 24-bit/192kHz) immediately skip or fail to initiate playback when casting from the Symfonium music player to my network devices (specifically, my Sonos system and smart TV via Chromecast/DLNA). Please don’t get mad if I type something wrong I don’t whant to get banned
Plex
One dot, there’s improvements.
Unfortunately there’s no logs uploaded …
On it I will fix the logs :slightly_smiling_face:
Well too bad you made me lost a lot time searching for non existing logs …
I just fixed the logs But After fixing the log file, the result I obtained was the error message, “This media is unsupported,” which is unexpected since all my files are FLAC, and the log provided no information on the skipping or playback failure. I’m sorry I messed up the logs it was a mistake :disappointed_face:
And there’s still no logs uploaded …
Have you read the wizard or the docs ?
