I’ve been casting to my Sonos device for a while now, and its always worked fine. For some reason though, today it no longer works. I’ve tried turning everything, including my phone, router, and the sonos device on and off again, to no avail. The device is found, I press play, then it never plays the song. It loads for a while, then tries playing the next one, so on and so forth.
While I’m here, one thing that also has never worked, is playing 24bit FLAC in Sonos. I know its not supported by Sonos, but could I configure Symfonium to truncate it to 16bit?
Upload description: logs when trying out different songs
You are trying to play offline cached media in opus Sonos does not support that, enable prefer server version in the renderer settings to force getting from server.
And casting to Sonos will work when Deluan implement the OpenSubsonic transcoding extension.
Changed my downloads to mp3 and it works as expected.
Note: As a newbie I was confused that ManagedMediaProviders > Subsonic > Transcode to MP3 did not actually transcode from Opus to MP3. Navidrome settings also did not transcode to MP3.
