Cast to kodi, without kodi as library provider
New to symfonium, but i think i understand right that it’s not possible to cast to kodi if it’s not added as library provider? Since i use my plex as provider, and on PC i have plexkodiconnect, i have double libraries if i add both as providers if i wanted to cast to kodi.
You can hide the Kodi libraries via the filter.
But the simple way is to enable UPnP on Kodi and play on it via UPnP
Figured it, yea via upnp is better, thanks.
For some reason thought kodi dlna settings were only for making it as dlna server, but i toggled only for control dont need it as server.
