Cast to Alexa Echo speakers
Is it possible to build an Alexa skill to cast from Symfonium to an Echo speaker?
Not sure whether it’s possible to somehow combine it with Yatse or any generic way to cast Android audio to Alexa Echo speakers, in general.
Cast music to Alexa Echo speakers without using Bluetooth (which drops out if moving the phone around the house). A cast solution that uses WiFi would work much better.
Cast music to Alexa Echo speakers without using Bluetooth.
 Not sure, maybe Yatse could do it. Or some other generic Alexa skill.
 Not provided
This is not possible, Amazon in the end never released the proper SDKs for that and all solutions some use are hack that can disappear at any moment if Amazon change it’s internal API.
The speaker/assistant/cast fragmentation is very frustrating for the consumer :frowning:
Is Sonos any better as a more neutral solution perhaps?
Sonos are UPnP and works well to cast from Symfonium, for the rest all depends on your needs.
Does it work directly from Smyfonium or does it need a helper e.g. Yatse, BubbleUPnP, etc.?
It works directly if your media are compatible or your provider support transcoding.
Any benefit to using BubbleUPnP? I’ve seen it mentioned in your Yatse. Why is this stuff so very complicated and confusing? I just want to send some music to a speaker.
Bubble is just a partnership to add transcoding to Kodi mostly for video and irrelevant here.
This would be a great user feature and a nice selling point for the app, given that Amazon Echo is one of the most omnipresent speakers in many homes nowadays. It looks like Spotify solved this problem, as I can cast music to my Echo speaker directly from the Spotify app, not using Bluetooth. Could something similar be done in Symfonium? Did I say I love the app :heart:
+1 from me for this feature.
This works really well with Spotify so it must be possible. As mentioned it would be a huge benefit to users with echo devices if there was some way of implementing it. Great app that I have only just discovered.
