Can't setup secondary connection but as primary works
Dear I’m trying to setup a secondary connection to the provider while using tailscale and I cannot save because it says cannot connect.
But if I setup a new provider with exact the same IP as primary connection it works as a charm.
That seems weird.
Ive uploaded the logs
Upload description: davdenic
Tailscale IP over http.
Jellyfin tested on several versions 10.11.0 - 10.11.3
Server doesn’t have valid SSL certificate.
Setup a provider via WiFi. Check connection works.
Turn off WiFi.
Turn on tailscale.
Add secondary connection with tailscale IP and port.
Save (it won’t saying it cannot connect).
Go back and setup another provider with the tailscale IP, port, user and password.
Save (it will and it starts syncing)
Yes when you save the primary connection needs to work.
You can bypass that if you wish by triple tapping the provider logo at the top then save.
Thanks that’s solved.
I had to try a couple of times but after was finally working had worked fine.
Thanks
Mercí
Vielen Dank
