Cannot cast to Plexamp
After version 14.0, I cannot cast to Plexamp on my Windows 11 PC. Older versions of Symfonium do cast to Plexamp with no issues. Any assistance appreciated.
Plex
Cast button, choose Desktop player (Plexamp), then nothing happens
debug.log
You are not trying to play or anything better describe your issue and what you do.
I am trying to play music on my desktop from my phone so that the phone is acting like a remote control for the desktop. I used to be able to do this with Symfonium on my phone which would connect to Plexamp on my desktop. But it no longer works although Plexamp appears as a cast target in Symfonium.
As asked provide useful details, no longer works can mean anything. What did you do in the logs ? What happens when you select the renderer ? What are you trying to play ?
Show screenshots / video / anything .
I thought I was very clear. Casting to Plexamp does not work at all with latest version.
Calling the mechanic:
User: Hello my car does not work.
Mechanic: Ok what is happening ? It does not start ? Does not move ? Make strange noise ? I’ll need more details to be able to help you.
User: I thought I was clear: It does not work.
I uploaded the log file. Did you see that?
Of course SINCE I ASKED YOU WHAT YOU ACTUALLY DID IN THEM …
Seriously, is it so hard to answer the simple questions and tell me what you see and provide the details and the screenshots ? Or do you just like to make us both loose time ?
