Cancelling a Sync, then running a Sync stalls before gathering metadata
If you begin a Sync, then Cancel it, the next (and all subsequent) time you do a Sync then it stalls at the end of finding all the Tracks and never gets to the gathering metadata stage
Navidrome
  1. Go to Source Filter, then Sync
  2. Cancel the Sync
  3. Press Sync
  4. The Sync will never get to the “gathering metadata” stage and will stall
Force Stop-ping the app or restarting my phone means that Sync begins working correctly once more.
Using the soft released prod build of v15
evilnicksyncstall
