Cambridge MXN10
Hello,
I’m considering buying a Cambridge MXN10 streamer. Does anyone use this device and can tell me if it’s compatible with Symfonium? Will I be able to stream content to this device and use it as a renderer?
Thanks in advance for your answers.
It has UPNP, bluetooth, and, a plethora of other connection options, so yes you will be able to stream to it from Symfonium if your client device also has any of those connections.
Thank you very for your reply.
My intention is to avoid Bluetooth and rely on UPnP/DLNA.
I was therefore wondering if Symfonium is able to discover and control the Cambridge MXN10 as a UPnP renderer on the local network, and whether there are any known compatibility issues.
Thank you for your help.
Symfonium can connect via UPnP so its shouldnt be an issue.
I can confirm that it works perfectly. The connection was established immediately without any difficulty. Symfonium on my phone acts as a remote control between the Navidrome server on my NAS and the NXM; it’s perfect.
