BPM info to my tracks using "beaTunes5.app"
I uploaded my sings with BPM tags filled out using “beaTunes5.app” for Mac.
Tag are not present in Symfonium App.
Using Android Moto g 2024
Upload description: emailbrentbarrett
Problem solved.
How do I delete this?
You don’t and give the solution for others ?
I decided that the issue was not really important so that is what “problem solved” means.
I could not figure it out so I’m moving on.
B
