Bottom Corner Button in Media Lists
Currently there is an option to add a row of buttons at the top of the media lists, but I would like there to be a “favorite” shortcut of one of these buttons in these menus that is located closer to the bottom corner of the screen for easier access (the thumb is much closer there to tap at that area).
The only location of these buttons are at the top of the media lists, and we can only disable the ones we don’t need which can leave some empty space.
Further customization to our media lists, as well as the convenience of having a button closer to our thumbs.
When opening a playlist inside of Oto Music, there is already a button at the bottom right corner to play the list of songs in order, or shuffle them if you press and hold the button. It can also be nice to have this same button in the playlist menu Symfonium.
The first screenshot shows what we currently have when enabling the top buttons inside of the media lists with the “normal” style while only having one button visible (what I would only use in these menus personally).
The second screenshot is a mockup of where this could button could be placed instead as an option for a “favorite” shortcut in the media lists.
