I am currently running an AOSP ROM with blur enabled (it works fine in other apps and such) but it doesn’t work inside of symfonium. When using the blurry background setting it just doesn’t apply and blur
Upload description: suyashtnt
I am running a custom ROM based off AOSP, but other app blurs are working find and adb reports blur being enabled. The regular blur setting works fine though, as seen in screenshot 2
Enable the blurry background style in extended video player settings.
