My album’s artwork are cover jpg files in the album folder. On grid view on my smartphon of my albums I see my artwork but on my car screen (android auto) they are blank. Why ? How to fix it ? Thanks
Upload description: Blank thumnails on android auto
Reboot the phone, enable logs in Symfonium, connect to AA, scroll in the AA interface to force load more images to be sure then upload the logs and tell me when it’s uploaded.
It is the latest vertion of AA (13.3.644654)
I use AAwireless adapter. It is also last update (4.5)
The strage thing is that I see few thumbnails on the Albums display (most are blank) but all thumbnails are seen when I switch to Artists display.
It seems that the albums that their artwork is shown on the album grid display in AA have the artwork embedded inside the mp3 tag. Otherwise the artwork is a file called front.jpg
However, The image is visible when I start playing any album in the player in AA.
In symfonium edit the provider settings and show the screenshot of the settings, there’s many different ways to configure it, need to know if there’s something special to try to repro;
Good morning
I send a new log file
The problem of the blank artwok thumbnails in AA was solved. I embedded all artwoks inside the music files.
However I have one more problem with Symphonium.
In my smartphone the albums display grid is sorted by the composer (artist) name.
But in the AA the albums display is sorted by the album name.
How can I change the sorting in the AA album grid display to be by composers (artists)
Thanks
