Bittare more then 320kbps
more bitrate options then 320kbps.
i have a high definition albuns with 24bit 96khz, and opus 320kbps compress more then necessary in cases like this
more quality audio in uncompressed high definition music
Other application solutions
native navidrome is customizable bittrate opus audio (510 max, opus limit)
There is absolutely no need for anything above 320 for opus for stereo content.
Only use case is > 6 channels and you usually do not want opus if you have the device to properly play those.
