Beta 15.0.0B6 - songLyrics v2 (from TTML) lyrics jump to the top after finishing some line
Beta
Syllable lyrics is jumping to the top after it finish a certain line.
I’m using the following Navidrome PR/Branch: fix(lyrics): correct TTML background-vocal cue timing and whitespace by deluan · Pull Request #5672 · navidrome/navidrome · GitHub
Navidrome
  1. Play song, shows lyrics + enable Karaoke mode
  2. Lyrics view jumps to the top after it reach the end for a certain line
The upload also contains the screen recording + lyrics file if needed.
naooooooo - songLyrics v2 jumping to start
Thanks will be fixed.
