Show the current battery level on the now playing screen in some way. a number, possibility for one of the text fields to be the battery or (preferably) a bar on the top or bottom of the screen (maybe behind the navigation bar if thats possible).
I think my mockups get the point across
Currently I use symfonium as a pinned app on my DAP so the battery isnt shown and I need to unpin the app to check battery status.
Much more coherent when you want to use a device for symfonium exclusively. Also would probably look better than the default android status bar
In the case of a seperate overlay app itll take extra battery and it wont be able to sync to the color of the album. also security considerations since I can’t seem to find any foss (or trusted devs) apps that do that
