Backup/Restore Only Smart Playlists
Ability to backup and restore only smart playlists.
Currently, the backup/restore process includes regular and smart playlists.
I don’t mind if there’s no option to backup regular vs smart playlists, what I really see useful is the ability to restore only smart playlists.
I use the local device, and all my regular playlists are imported (as read only) from m3u files when synching. I also have smart playlists that I created on my own.
I do keep a backup to restore from scratch in other devices. However, I’m not interested in restoring regular playlists, since they still come from m3u files that are up to date; but I’m interested in restoring my smart playlists, because there’s no other place they are stored.
With the current restore process I endup with duplicated regular playlists: one set of playlists coming from the backup file, and another set coming from the m3u files during the sync (that happens after restoring).
A bit more control over what kind of playlists I’m interested in restoring.
Another way this could be solved is by having an option to replace playlists with the same name during the sync process to prevent duplication.
You can already export / import manually just smart playlists.
But most importantly the restore should not create duplicates as there’s uniqueIds checks.
Please open an issue with logs during a restore to see what is happening.
Will do shortly, thanks.
Even though this was marked as won’t implement, it ended up being implemented a few versions later, nice!
