You should change the color selection that the player makes and select the second most predominant color of the cover to apply to the background of the player.
This should be done because there are many inconsistencies with some colorful covers, in which the player selects a dark color that is not very predominant on the cover of some songs.
I see this happening when I select the appearance of the player in dark mode.
Also, I think it would be nice if you could separately select the colors of the application (light and dark) and the colors when a song is played (light and dark). That way, you could have the app look light and the background of the songs could take on the appearance of dark mode, which has a wider color palette than the background of the player in light mode.
I think the option to change the shape of the center of the music player should be added to change the square appearance of the button for a circular one (spotify, YouTube music), more rectangular, flower shape and other variables that “material you” allows.
I am happy to have purchased this player. The support provided by the application is incredible. You’re the best.
Upload description: You should change the color selection that the player makes and select the second most predominant color of the cover to apply to the background of the player. This should be done because there are many inconsistencies with some colorful covers, in which the player selects a dark color that is not very predominant on the cover of some songs. I see this happening when I select the appearance of the player in dark mode. Also, I think it would be nice if you could separately select the colors of the application (light and dark) and the colors when a song is played (light and dark). That way, you could have the app look light and the background of the songs could take on the appearance of dark mode, which has a wider color palette than the background of the player in light mode. I think the option to change the shape of the center of the music player should be added to change the square appearance of the button for a circular one (spotify, YouTube music), more rectangular, flower shape and other variables that “material you” allows. I am happy to have purchased this player. The support provided by the application is incredible. You’re the best.
