Posiibility to use autoupdate for playlists, so every time when some song is added to the playlist this playlist is send to Jellyfin server. And every time when i open playlist on my Symfonium app, playlist from server is download to the device (or check that is this same)
Problem with use playlists on many devices.
It simplyfy process of creating playlist when user use many devices, for example PC, Jellyfin WWW GUI, Symfonium etc…
On every app that play music from Jellyfin server playlist are automatically updated. I only cant set this on my Symfonium app, but i preffer Symfonium over every other app becouse many features and possibility to configure almost everything.
Thank you for the information. I cant find anything related to this, and never think about use “import” button.
Description look like “online first” is option for me. Can you tell me how to “force update” those playlist? I make small test, add some music to playlist on my PC. Then i open Symfonium App and playlist show “old version”. Again i need to use Synchronize and download from server to update it…
It dosn’t work for me in both directions… I can not upload my Playlist to the Media-Source (download work, but don’t sync / merge, but “overwrite” the whole Playlist!
If you now go to your symfonium client (android) and add another track (magenta colored one) and press the sync-button… and choose upload to media-source…
