Just like it works for jellyfin I would like to also have the option to distinguish which subsonic libraries should be automatically cached inside one provider.
Navidrome has added multi library support recently, and in the filter settings all libraries are shown. One can just not set the rule to only select some off them to be cached automatically.
Add a feature for subsonic that exists for jellyfin server provider.
Brings already present feature to subsonic provider
