Autodelete generated Media Queue
I think there should be an option to not add Song Mixes to the media queue or to autodelete it after some time because it fills the media queue quite easily if you create a Song Mix every day like me.
Media queue filled with generated playlists.
A cleaner media queue.
Media queues are auto removed in all cases only the last 15 are kept.
Mixes are a normal queue and needs to be created as such to be able to be restored when app is killed, so not sure how it can be avoided.
Hello, new account here
Personally, I really prefer to just browse my library directly at the tracks page instead on the media queue. I tend to forget that the media queues were piling up so I had to manually clear past queues everytime I wanted to listen another song.
There’s no limit that prevents you from playing something else. If you don’t use the Queues to resume playback, you never have to touch that menu. Old queues will auto-delete to make room for a new one.
Play your tracks normally and everything just works. No need to clear anything.
