Auto lyrics from lrclib or lyricsfy
It would be a great addition if there’s a feature for auto searching of lyrics from lrclib or lyricsfy, wether it’s unsynced or synced, just like Aonsoku.
Less time in manually adding lyrics on each metada of the music files
Lyrics automation
Duplicate of this. Won’t be added since it would require a change in the Symfonium content declaration on Play Store according to Tolriq.
In addition to the tools Tolriq mentioned in his reply (MusicBee, Lyrics finder) you should take a look at lrcget, which can automatically fetch lyrics in bulk from lrclib.
However I’m personally not a friend of auto fetching lyrics. The majority of the results (for me) was either inaccurate or outright wrong.
use songsync app found in GitHub, it’s for android
