Hello, I bought a seedbox and installed Audiobookshelf. Unfortunately, this app is weak, so I ended up using Symfonium
It looks great! Unfortunately, I don’t see a way to add a NAS or something else for syncing, so I added Audiobookshelf. Unfortunately, I get an error during syncing. Does Symfonium support larger file sizes?
Audiobookshelf
Settings
Sync Manager
AudioBookShelf
Selecting Sync
Preparing sync
Shows Callers, albums, and songs, then pops up: Failed, check logs if this happens frequently.
Mecenas
