Receiving an error msg to check firewalls and that the media is provider is running
Audiobookshelf
- Attempt to login w/ ABS when using a reverse proxy
- Currently have jellyfin working w/ Symfonium via zoraxy (reverse proxy) so that I can use jellyfin.lan and route traffic through
:443 - I successfully use https://abs.lan for the official ABS app
- When attempting to set up ABS w/ Symfonium, naming the port et al is not present for ABS yet so I tried logging in w/ API Key as well as
https://abs.lan:443/andhttps://abs.lan:443. None of them work - I exported the logs, but it appears that failed attempted connections do not print error msgs to the logs, so I don’t think it is of any use. Exported anyways
Theories/Thoughts
- Cannot set up hostname+port for reverse proxy which is required for my connection
- Self-signed certs are not available for ABS?
- Logs need to include attempted/failed connections for new media providers
macallik
