The app has most of the basic audiobook options which are great but would love to see a few extra features if possible.
• Support for chapters in m4b and mp3 files.
• Skip Silence.
• Voice boost.
• pleasant color scheme by extracting colors from the cover of the album like what Plexamp does.
Never used chapters can you share privately a file with those so I can see what data Plex returns?
Same a file with silences so I can see if plex returns info about those.
For voice boost, I’m not sure the engine I use can do that, can you describe what you expect from it?
For the color scheme there’s color extraction for the now playing screen already, during navigation for the moment I preferred to keep consistency considering material you and custom importable themes.
Thanks, for the colors open a different thread with details, but this kinda defeat the whole material you theming. There’s currently no API to really manually generate a full m3 theme from an image. Seems they landed the code in 12L AOSP but not looked into that yet, so open the issue for later check.
