I bought your app long time ago because it had audio passthrough for my dts and dtshd (flac) files. I dont know again what option i used for it but now in this version i can find it anymore.
No that did not solve my problem, it used to work maybe its my new media box.
Can u implement it as a new feature…i now have to work with finamp but symfonium is better…i guess a lot of audiphiles will love the feature
Ive got a jellyfin server on docker. I use finamp on my android tv box
Its connected to my pioneer receiver,
If i play the file from finamp, its not transcoded but plays fine on my receiver.
They are multi surround audio files…dts or dtshd in flac
If i want to play them on symposium it gives media not supported notification.
I could play them in the version i bought about a year ago
I can enable transcoding but then the files are played stereo not surround
I solved the problem, i rebooted de android box and enabled internal encoder, now it plays the flac multi surround, sorry for the trouble…and i can use symfonium again…Jippie…
