Would it be possible to add an audio normalization checkbox or setting? It could be beneficial for libraries with songs from different sources which have different volume levels.
Some possibly helpful links:
This is not really possible without getting the information from the provider, Symfonium can not analyse all the files itself it’s not it’s purpose.
No worries. Thanks for the reply!
If you cache the music offline can is it possible to have this functionality?
It’s not tied to being cached or not, just require that the media embed the tags, this was added later when finding a way to extract from the player.
So you are saying this is now possible and should be working as long as the tags are there?
You need to enable it. In settings playback equalizer enable replay gain.
