Audio files not showing
I connect it with my gdrive there were some files already, after that i uploaded some new files to it.. but not appearing in symphonium. Please help
Upload description: i dont think it has logs for it
Google Drive
Well if you know better than all the messages that says otherwise :wink:
You probably just forget to sync the provider. Use sync manager in the settings ?
Thanks i found sync option.. I was pulling down in the app thought it would refresh or sync…
