Clean install, defined the media provider, audible artifacts not present in FLAC files streamed from Jellyfin hosted on a TrueNAS server. Turn on the processing engine and random popping artifacts can be heard. Turn the processing engine off again and the artifacts disappear.
I have heard this on both my phone and my tablet and stumbled across it while applying an AutoEQ for my headphones. I can reproduce this on both devices with the AutoEQ enabled and disabled but still having the processing engine turned on.
Upload description: Artifacts in audio with processing engine turned on - 4ipqiaxm
Devices used: Google Pixel 6 / Lenovo Tab P12.
Clean install, define media provider, enable processing engine and stream FLAC audio from Jellyfin hosted on a TrueNAS server. No other settings were changed.
Turn off processing engine and artifacts disappear.
Huh, that’s odd. I had to enable offload because of artifacts and the settings I have with the processing engine (EQ, limiter and preamp) are applied. Must be more Pixel weirdness.
After extensive testing it would appear that the artifacts are most likely caused by the LDAC codec upsampling 44.1kHz content to 96kHz. I cannot make the lower sampling rate persist so I have switched to AAC 44.1kHz / 16 bit and have had no further issues.
