Artist Page for Ill Niño
Ill Niño isn’t showing up. My provider is Jellyfin, and Ill Niño shows up fine under it. The albums have been retagged via l!darr (musicbrainz) import. The tracks are offline synced and I can search for them in Symfonium. Another thing… when in a Ill Niño song menu I only have the option to “Go to Album”. Usually “Go to Artist” is right underneathe it.
Upload description: holycow131415
The usual Jellyfin bad handling with duplicated internal artists not exposed via the normal endpoints.
The initial duplicated artist returned by Jellyfin is “Ill Nino” without the ~ so Symfonium can’t match them as no API for that …
Rename the duplicate “Ill Nino” to “Ill Niño” and Symfonium will be able to workaround the Jellyfin issue.
Ohhh that’s interesting. So in Jellyfin the Artist page didn’t auto update from the metadata of the files? In jellyfin I updated the Artist name and now it shows in Symfonium after a sync. So does LMS media provider better support this? I’ve been using lidarr to change the metadata of all my files last few days so wondering if I’ll run into this again.
Yes GitHub - epoupon/lms: Lightweight Music Server. Access your self-hosted music using a web interface. works better and in all cases unlike Jellyfin @itm is actually willing to improve any handling issues it could have.
