Artist artwork 'Generate from tracks:
Hi, I’ve tried using the ‘generate from tracks’ option to populate some missing album artist artwork but it doesn’t seem to be doing anything. I’ve used this in the past and it’s worked great.
I’m using opus files, located on local SD card
Upload description: DWR10305
View album artist in the library where no artwork was pulled back by the scraper.
Click three dot menu and select ‘change local thumbnail’, then select ‘generate from tracks’
You have no tracks for that artist in the logs.
Thanks Tolriq. I think this is probably down to my wanky implementation of artist and album artist causing a mismatch. That’s fine I’ll change my tags and retry.
Happy to close this one.
Cheers
