Additional option to hide the headers in the “About” section of the Artist and Album pages. (Referring to e.g. “Genre” header text while still displaying the content)
Headers can take up a lot of space and may break up the look of the desired layout.
Depending on the category, header may not provide useful info (e.g. if the data is “United States” the user can probably guess the category is “Countries” )
Allows space saving if headers are not needed/desired
Allows closer grouping of data, since there would be less separation between fields.
For example, could have “Record Label” header showing, followed by the fields: “label, country, language” inside a single visual group.
Pic 1: screenshot of current Album page. Headers are shown, taking up space and breaking up the fields
Pic 2: Mockup with all Headers removed. Vertical space needed is reduced.
Selectively leaving only some headers in Pic 2 would allow multiple fields to fill one “visual group”
I have set “CD ” for CD Media Type not audio quality, “Lossless” badge is the popular choice for 16/44 quality. You can use a simple format.samplerate && format.bitdepth syntax to show “CD” or “CD Quality” as Qobuz does if you want
Not sure where to ask but here: How do you actually get this line with “Compilation | 2008 | …” on the Album page? I’m not seeing any options to display anything else but the About section. The line even utilizes custom strings? I know that in another feature request, you suggested custom string lines for the album page, but they’re not yet accepted nor implemented.
V14 will actually give you one slot to replace the current Subtitle. So you can’t do this yourself right now but the official version should be out very soon.
