I am not familiar with collecting Android bug reports - do I start the bug report, use Symfonium, then stop the bug report?
OR, are the bug report and log independent of each other?
I don’t see anything different in the dump between start of playback and change of songs.
When Symfonium is already playing and you connect to the car the art is correct?
When player is stopped then you start a song the art is correct?
When you press next the art is correct or not?
When you start playback of something new from Symfonium the art is correct or not?
When the song auto skip to next the art is not correct?
When Symfonium is already playing and you connect to the car the art is correct? Cover art incorrect
When player is stopped then you start a song the art is correct? Cover art correct only if Symfonium has been force stopped and started again
When you press next the art is correct or not? Cover art incorrect
When you start playback of something new from Symfonium the art is correct or not? Cover art incorrect
When the song auto skip to next the art is not correct? Cover art incorrect
It appears that the cover art is only correct the first time Symfonium is started
