App switches to interal storage location
Hi,
1st off…thank you so much for this absolutely awesome app…! I use MusicBee extensively and this is on a par - so congrat’s!!
Ok - The issue is that I have set the app to automatically add favourites to offline cache, and the location of offline files to the SD card (external). Every so often it automatically switched back to Internal for the location, and tried to download music that it cant find (I think that is what it’s doing). The problem is that I don’t have a good amount of space for these files which is why I have an SD card.
It was doing this numerous times so I decided to turn on the logging mode, and this seemed to stabilise things for a good number of weeks until today (so I am also apologising for the extensive log file you should receive from the app).
I was wondering if this is an issue or if I am doing something wrong. Either way, could you have a look into it please?
Many thanks in advance
Upload description: jmw_internal_external
As an additional problem that seems to be linked - I notice that when I turn it back to external storage, the settings that I have edited are reverted back to some kind of default; so the grid size of the media shown, and the sort order. This isn’t too much of a problem but it seems that something strange is going on
N/A
Subsonic (Navidrome)
There’s no logs uploaded probably too large.
This can only happen if the app is started and the sdcard is not mounted before it timeout.
ok - thanks
I’ll check the SD Card in that case - it is probably getting a bit old, so maybe that’s the issue.
Thanks again for the app!!
