Anyone help me to fix track name problem
Anyone tell me how do i fix the track name problem of a song, it showing a file name instead of title of the songs, after the update this glitch come.
You can use any tag editor (like Mp3tag or Kid3) to check what your “Title” is set to and change it if needed.
You can also try to “Clear tag cache” in the Media Provider settings and do a full rescan.
If those don’t work for you, probably ask in Support .
