This is something that similar apps like Pixel Player and Booming Music do. This usually happens during an instrumental or solo. Would love to see some implementation in Symfonium.
Right now there’s not a whole lot you can do with the blank space for lyrics other than adjust the height for each lines.
Implementing this would help provide more customization for lyrics. It would also help make instrumental or solo sections of songs more enjoyable if you’re like me and use the lyric feature all the time. You could also add a toggle in the options to disable it if you prefer the blank lines.
Other application solutions
They put a little animation when there’s a blank line in the lyrics. Booming Music by default displays but you can toggle an option to ignore the blank lines if you what.
