I’m using Symfonium on my Android smartphone and on Android TV with Airsonic. On my smartphone I can use the filter feature to unselect some of my media folders. On Android TV I can get to the same dialog, but there’s no way to unselect any of the media folders using my remote. I even plugged in a keyboard, but no luck.
Additionally the same issue occurs with the “skip 30 seconds” button when playing a song. On Android TV the button doesn’t do anything.
Upload description: Faeb35
