Android intents via macrodroid
Please advise on what I am doing improperly via this android intent.
I am attempting to start a playlist “Macro” to no avail.
Upload description: Macrodroid Intents
Also the documentation regarding using internet to regenerate playlist thumbnails states the Long parameter
“The playlist ID (Can be seen at the top of the playlist action bottom sheet)”
I don’t know what that means /where that is
I’ve never used an android intent before. After following the wiki article I’ve gotten this far & running this action in macrodroid seemingly does nothing which leads me to believe I’ve made a heinous mistake or two.
The name does not go in data but is also an extra value as per the doc.
:face_exhaling: yep that did it
Thanks again
“QUEUE” [Int/Optional/1.8.0+]: 1 to queue the media at the end of playlist. 2 to queue the media just after currently playing one.
This part of the documentation is flipped for me.
Meaning the value 1 for me adds the song after the currently playing one & the value 2 adds to the end of the queue.
@Tolriq please advise on the “Long Parameter” for generating playlist thumbnails via intent
I’m not sure how / where to find the playlist ID as it appears not to simply be the name of the playlist
Just use the name then :slight_smile:
It’s explained in the data you gave, press 3 dots on a playlist and the id will be visible in the header.
There’s also a few other posts about that, I can’t do that level of support for all users.
