Android auto steering wheel "next" command jumps 2 songs
Symfonium 5.5.0 (1030)
Ford Focus Android auto
the behaviour is quite strange
When Symfonium is on main screen of android auto and sterreing wheel commands are used for next/previous, or when tactile screen commands are used for next/previous, it jumps only 1 song in playlist => normal
When Symfonium is switched to the secondary android auto screen, the use of steering wheel commands for previous /next jumps 2 songs. tactile commands works flawlessly.
debug-20230726_092736.zip (649 Octets)
I need logs reproducing the issue.
how to do ? activate debug ?
The template you deleted explained all that and gave the links for the doc.
http://support.symfonium.app/t/wiki-how-to-gather-logs-and-open-an-issue/18/2
I guess we’ll never know.
You’ll know next Time i use the car.
debug.log (1,4 Mo)
Heres the log
When its on thé player on Android auto thé next button on steering wheel jumps 2 songs. When its on thé playlist on Android auto thé button correctly jumps to thé next song
Got them by mail earlier.
This is a mix of your car sending non standard events and the Google library not handling them properly.
Will add a workaround in next release.
