I created a few smart playlists but they don’t show up in the Playlists screen on Android Auto. Can this be implemented?
Thanks
Thanks
They are not visible in the playlist part of AA or you do not have the playlist part in AA at all? (Can you see normal playlists?)
What version of Symfonium?
Hi
Version 1.0.0. The Playlist screen is showing in AA but it doesn’t show the smart playlists
Thanks
Can you confirm that the playlist you don’t see are albums playlists ?
Yes that is correct.
Ok will be fixed in next release.
Great, this was something i was meaning to suggest as well. Is there anyway to have AA mimic the same setup you have on your phone by any chance?
What do you mean. by that?
