Android Auto Shuffle Applies to Entire Library
If I start playback of my favorites from the Android Auto UI and apply shuffle, the next tracks will be played from my entire library, not just from my favorites.
Upload description: Aether - android auto shuffle issue
Ensure that no media is playing on the app. Connect to Android Auto, then within the AA UI go to “favorite tracks” play a track, then tap the shuffle button. Press the skip button one or more times, and a track not on your favorites may play.
Plex
You have enabled smart queues when you reach end of queue it will queue new songs based on your settings.
I see. In that case, shouldn’t the rest of the favorites be added to the queue when starting playback from the favorites menu? That way it is consistent with the main UI.
It does in the limits of AA and the shuffling.
Sorry, I’m not sure what you mean. I don’t see any shuffle button for the entire favorites list, if that’s what you are referring to.
You can also just create a smart playlist and play it shuffled.
