Android Auto - 5-star rating vs Smiley face in Android Auto
I’d like to propose a small change to how ratings are represented in Android Auto.
Currently, the faces are mapped to star ratings roughly as: 1★ → :frowning:, 5★ → :slightly_smiling_face:, and 2–4★ → neutral face.
Instead, could Android Auto use the faces to clearly distinguish between “rated” and “not rated” tracks, for example:
Unrated track → neutral face
Low rating (1–2★) → :frowning:
Positive rating (3–5★) → :slightly_smiling_face:
This keeps the 5‑star rating model in the main app, but makes the Android Auto UI more usable and readable while driving, without adding new controls or extra complexity.
When driving, the current neutral face for 2–4★ ratings is ambiguous, because it looks the same as an unrated or “unknown” state.
As a result, I often cannot tell at a glance whether I have already rated the current track, which is distracting and can lead to repeated rating attempts while on the road.
This ambiguity increases cognitive load and attention time on the screen, which goes against the goal of keeping Android Auto interactions simple, predictable, and as distraction‑free as possible.
Clear state awareness while driving: I can instantly see whether a track is unrated, liked, or disliked, without needing to remember past actions or navigate additional menus.
Reduced distraction and safer use: Faster recognition of rating status means less time looking at the screen and less mental effort, aligning with Android Auto’s design focus on minimal driver distraction.
Better use of ratings: Because it’s obvious which tracks are already rated, I’m more likely to rate new tracks consistently and adjust bad ones, improving the usefulness of my library over time.
Small change, high impact: This is a simple mapping adjustment in Android Auto’s icon logic, but it meaningfully improves UX for users who rely on the 5‑star system.
Other application solutions
This pattern helps drivers quickly understand status without needing to interpret exact star counts, which is the same improvement I’m aiming for here in Symfonium’s Android Auto view.
I previously raised this request some months ago and completely understand you have many competing priorities.
The main motivation for revisiting it is driving safety and usability rather than aesthetics: distinguishing “rated” vs “not rated” is much more important in the car context than showing the full granularity of the 5‑star system.
I’m a heavy Symfonium user and rely on ratings to manage a large library, so having this clearer visual distinction in Android Auto would significantly improve my day‑to‑day experience.
Of course, I’m happy with any implementation that achieves the same goal (for example, using any other simple icon scheme that clearly separates unrated, negative, and positive tracks).
This is something I would greatly appreciate, and could see further!
I rate my music when listening as much as I can as well, and this is partially why I rarely listen to new music when in the car unless I have a co-pilot (As this way I cannot rate songs as I am listening to them)
With the (not really that recent anymore) update that overhauled the visuals and little effects I am really curious as to what can come next. I thought it was impossible, but now I’m thinking of the stars when you’re on Now playing, as it seems size could be adjusted ( Settings - Playback - Notification/Media session buttons | Symfonium Docs seems to say you can have a maximum of 5 buttons plus pause in Android Auto, and since my car has physical buttons for skipping that would be perfect for ratings for me, but it might be a bit more farfetched)
Yeah. Unfortunately, I never got an update on my original question.
When I listen to music I need to rate, I use Plexamp, as the integration for ratings works perfectly. Otherwise, I use Symfonium
That’s a real dang shame.
Plexamp could work for now, though I bought this app because I didn’t want to deal with some of the more annoying aspects of that one, and so I could stick to the same app after I switch to Navidrome from Plex.
I’m honestly suprised this is still just stuck as triage.
Unfortunately, I don’t think it will ever be implemented. This was the second time raising it, as the first was a year ago. I have reverted to Plexamp while driving.
