The only options i see are export and uploads in the app.
I did all my json testing in ultrasonic and xml with dsub and supersonic but symfonium doesn’t sync or load data.
How do i get information about the errors out of it?
I know it will be another data error of some kind but i don’t know where to find out the answers.
What i can see on the server is the search call is going past the amount of artists and then gets stuck.
[02/Jul/2025:19:30:09 +1000] "GET /rest/getOpenSubsonicExtensions.view?u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:30:20 +1000] "GET /rest/getStarred2.view?u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:30:20 +1000] "GET /rest/getBookmarks.view?u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:30:21 +1000] "GET /rest/getGenres.view?u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:30:21 +1000] "GET /rest/getMusicFolders.view?u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:30:21 +1000] "GET /rest/search3.view?query=%22%22&songOffset=0&songCount=0&albumOffset=0&albumCount=0&artistOffset=0&artistCount=500&u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:30:21 +1000] "GET /rest/search3.view?query=%22%22&songOffset=0&songCount=0&albumOffset=0&albumCount=0&artistOffset=107&artistCount=500&u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:30:37 +1000] "GET /rest/search3.view?query=%22%22&songOffset=0&songCount=0&albumOffset=0&albumCount=0&artistOffset=107&artistCount=500&u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:30:40 +1000] "GET /rest/ping.view?u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:31:07 +1000] "GET /rest/search3.view?query=%22%22&songOffset=0&songCount=0&albumOffset=0&albumCount=0&artistOffset=107&artistCount=500&u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:31:10 +1000] "GET /rest/ping.view?u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:31:40 +1000] "GET /rest/ping.view?u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
[02/Jul/2025:19:31:52 +1000] "GET /rest/search3.view?query=%22%22&songOffset=0&songCount=0&albumOffset=0&albumCount=0&artistOffset=107&artistCount=500&u=demo&t=token&s=salt&v=1.13.0&c=Symfonium&f=json
Upload description: lachlan-00
new implementation so probably bad data types
