Amoled or Transparent Navigation Bar
I would like the option for an amoled navigation bar to match the amoled theme. I would also like a transparent option too.
Currently you can only set the navigation bar to be dark with the rest of the UI being amoled black and this makes it look jarring. If these options are provided it would smoothen things out.
It would make the home screen UI look more uniform.
Namida has made an excellent effort with it’s own amoled navigation bar. Simp Music has done a great job too with it’s transparent navigation bar.
Just to be clear I only want the navigation bar to have these options. It shouldn’t include the compact now playing bar. Also it wouldn’t hurt to curve the edges of the now playing bar a little.
Screenshot one is the current navigation bar on Symfonium.
Screenshot two is from Namida.
Screenshot three is from Simp music.
Just change the surfaceContainer color of the theme to whatever you like.
Please how do I do that?:pray:t6:
Read the doc about custom color themes ? :slight_smile:
Sorry, just saw that and I’m going through it now. Thanks.
Unfortunately I’ve gone through the doc and tried out the listed information and it works on the dark theme but it doesn’t work on the black theme . It reverses. Screenshot 1 is how it is on the regular dark theme. Screenshot 2 is how it is on the black theme, I don’t know if this is a bug or not.
Again please use a custom theme … you can configure every single color of the app…
Ok I figured it out. Thank you once again :pray:t6:.
