Alternative location for export of playlist
Is it possible to have a browse option for the export, then we put it where we want? Create a new folder, drop it in the Music folder, etc?
Is it also possible to have the export folder also automatically updated when the playlist changes, like your read-only mode and offline cache for the playlist?
The app only allows you to export to the downloads folder. Worst yet it goes right into the root of the downloads folder. This is messy and not optimal.
I have am having issues with the shuffle and read-only playlist for live caching and wanted to switch back to the other app I purchased as it has a more sophisticated and reliable playback and shuffle mode but I love the integration your app supplies with my Navidrome server.
Why not actually explain your issue with logs and details so it’s fixed ???
This not the case, it goes in subfolders.
Not possible and the reason why offline cache is internal to the app.
So since your need is actually to fix a shuffle issue why not just fix this ?
