While on the Now Playing Expanded page, if you swipe to the right on the media controls (pause/play, next, back) it will scroll and show the lyrics in a scroll-able mini container (which you can then enlarge into the normal mode)
Replaces having to tap near the cover art with a gesture instead.
Allows further customization for users, and allows them to quickly check the lyrics.
