Album tags
A way to tag albums similarly to how playlists can already be tagged and separated into tabs. For example, tagging albums as “Studio albums” “Live albums” “Soundtracks” “EPs” “Singles” etc. would allow for a more organized layout. The different tags would show up as different tabs in the artist and album-artist page
Currently having all albums sorted in the same category creates a messy layout in the artist page
More organization and customization
You can already with album release type.
I’m sorry, I seem to be a bit lost… How would one access that?
They are well know tags you put in your files.
What is your provider?
My local device is my provider
Then use a tag editor to put that data in the files and Symfonium will use it.
Yeah, the problem seems to be that I can’t find a tag editor that works on mobile and that allows me to edit those kinds of tags. Thank you though
Highly suggest MP3tag if you have access to a computer, would save you a heap of time tagging
Thank you! The problem is that I don’t have access to a computer, but I ended up discovering that kid3 has a downloadable Android version that after some tinkering with worked for what I need!
