Album sorting by title - problem with numbers
Hi, I am using symfonium’s library mostly by choosing albums and sorting them by title, however, one small issue is bugging me - I got 10 albums from the series titled “Haydn 2032 - No. (numer) - (title)”, and the 10th album is sorted right after number 1, not after number 9. Is there any possible option to change that?
Upload description: kw1990
Use the album sort title tag to fix the sort.
Edit tags to 01-02-03 etc.
Ok I had to search a bit to get to know what you’re talking about but I got it and it works like a charm, thank you :slight_smile:
