Album art cropped for some releases
If image size is set to large, it often gets cropped down from a square to a rectangle (but not always)
Upload description: PANICBUTTON
  1. Set header to large
  2. Set image to large
And would that be the case after all the messages everywhere that says otherwise ?
My apologies, I incorrectly assumed this UI issue would not show up in the logs. I have uploaded them.
The UI itself no, but it have your settings, your phone details, Android details and Symfonium version details.
That’s why it says issues without logs are ignored.
Do you have any idea of the difference between the 2 cases ?
Are they always the same albums or it’s random ?
I can not find any notable differences between the two albums. I will check again.
The same albums and artists always render the same way.
I’m having issues uploading images to this site, but here is another album that is rendered incorrectly (but differently than BODIES above; the bottom of the image doesn’t overlap with the body): Screenshot-20250917-123541 hosted at ImgBB — ImgBB
And here is an artist whose image is rendered incorrectly: Screenshot-20250917-123559 hosted at ImgBB — ImgBB
